28 June 2022 / Last updated: 28 Jun 2022
Using NFS Server to share external storage between containers
Cost: Low
At Theia Scientific and Volkov Labs, we created the Theiascope™ platform, which includes an application specifically designed for Machine Learning (ML)-enhanced microscopy that makes real-time analysis on any digital microscope possible. For managing our test and production fleets deployed at universities, government laboratories, and commercial scientific facilities, we rely on balenaCloud.
Set up NFS Server to share external storage between containers
We have a great experience using balenaCloud to deploy Docker containers and enjoy an effortless upgrade process consisting of creating Docker containers using GitHub Actions and pushing new releases in an automated way following our release schedule.
Following containerization best practices, the Theiascope™ platform is separated into containers deployed in host network mode and interacts with each other using TCP and/or UDP ports. The Theia web application running on the Theiascope™ hardware powered by balenaOS deals with massive data, where exporting results can reach gigabytes in size. To prevent caching and delay in transferring files between containers, each container should have access to the same storage.
UPDATE: Check out the example project on balenaHub. It's now available as a way for the community to try this solution out.
About the solution architecture
The Theia web application consists of multiple Docker images, notably:
  • A PostgreSQL database container with an external NVMe SSD.
  • A REST API server connects to the PostgreSQL database and exposes an API utilizing a reverse proxy for URL mapping and an additional layer of security.
  • A NGINX reverse proxy provides access to REST API and Grafana UI running in a separate container.
Recently, we implemented new functionality to export processed scientific data, which should be available to download from internal networks and balenaCloud. In a network-constrained environment, the API container stores multiple ML models, weight files, and cache, which requires additional storage space.
As a permanent storage, we utilize NVMe SSDs connected to the Theiascope™ hardware via a M.2 socket. Unfortunately, balenaOS does not allow sharing external storage between containers. Scanning thru the community forum, we found two solutions – using journaling or the Network File System (NFS) client/server architecture.
We decided to go with the NFS client/server architecture, as shown in the diagram below.
Use NFS server to share external storage between containers on balena
Architecture diagram for NFS Server/Client connecting multiple Docker containers.
From a performance point of view, the PostgreSQL container is an ideal candidate for the NFS server. The NVMe SSD was already connected to the PostgreSQL container following this post on the community forum.
NFS Server
As mentioned, we build all our containers using GitHub Actions. We are using the Timescale base image for the PostgreSQL container, which is based on Alpine Linux. We started experimenting with the most recent version of Alpine Linux and ended using an eight-month-old image. The latest version of nfs-utils is not compatible with the current version of the Linux kernel included with balenaOS for NVIDIA Jetson devices (target deployment hardware).
Here is how the Dockerfile looks:
FROM timescale/timescaledb:2.4.2-pg13
## Application-specific logic removed ##
## NFS Server
RUN apk update && apk add nfs-utils openrc
RUN rc-update add nfs
## Entrypoint
COPY entrypoint.sh /entrypoint.sh
RUN chmod +x /entrypoint.sh
ENTRYPOINT ["/entrypoint.sh"]
CMD ["postgres"]
Looking around the Internet on how to start a NFS server in Docker, you can find various projects utilizing custom scripts developed more than three years ago. In our solution, we are using the OpenRC init system to start a NFS server.
NFSv4 modules are not currently enabled in the current Jetson kernels, thus we are using NFSv3. Our entrypoint script looks like this:
#!/usr/bin/env bash
## Application-specific logic and mounting NVME storage removed ##
## Export NFS Mount
echo "${MOUNT_POINT} *(fsid=0,rw,sync,no_subtree_check,all_squash,anonuid=65534,anongid=65534)" > /etc/exports
## Load modules
modprobe nfs
modprobe nfsd
modprobe nfsv3
## NFS Server
rm -rf /run/*
mkdir /run/openrc
touch /run/openrc/softlevel
openrc
exec docker-entrypoint.sh "[email protected]"
Before starting the NFS server with RPC (Remote Procedure Call) processes, we manually load all required modules. To load modules and start the server with dependent processes, Some balena-specific labels are needed. More information about labels can be found in balena’s documentation.
To start the NFS server we added three labels:
  • io.balena.features.kernel-module to bind mounts from the host OS /lib/modules directory into the container (i.e., /lib/modules:/lib/modules).
  • io.balena.features.sysfs to bind mounts from the host OS /sys directory into the container.
  • io.balena.features.procfs to bind mounts from the host OS /proc directory into the container.
Our balenaCloud docker-compose file for the PostgreSQL container looks like this:
 postgres:
   container_name: postgres
   image: ghcr.io/POSTGRES-IMAGE:latest
   restart: always
   network_mode: host
   labels:
     io.balena.features.kernel-modules: "1"
     io.balena.features.sysfs: "1"
     io.balena.features.procfs: "1"
   environment:
     - PGDATA=/mnt/nvme/postgresql/data
Privileged mode is required for both the NFS server and client containers to start the mountd process and mount NFS drives and/or shares. Instead of the Privileged mode to fine grain control you can use Linux Capabilities, but we have not experimented with them at this time.
To verify that the NFS server is running, the portmapper (Open Network Computing Remote Procedure Call service that runs on network nodes that provide other RPC services) can be queried with the command, rpcinfo -p, to find out what services it is providing. An example output with the NFS server running is seen below:
# rpcinfo -p
   program vers proto   port  service
    100000    4   tcp    111
    100000    3   tcp    111
    100000    2   tcp    111
    100000    4   udp    111
    100000    3   udp    111
    100000    2   udp    111
    100024    1   udp  56971
    100024    1   tcp  56971
    100005    1   udp  64101
    100005    1   tcp  57033
    100005    2   udp  63895
    100005    2   tcp  51037
    100005    3   udp  58962
    100005    3   tcp  53357
    100003    3   tcp   2049
    100227    3   tcp   2049
    100021    1   udp  61320
    100021    3   udp  61320
    100021    4   udp  61320
    100021    1   tcp  53171
    100021    3   tcp  53171
    100021    4   tcp  53171
If TCP port 2049 is listed, then the NFS server is properly configured, running, and ready to accept requests from clients.
Exported NFS volumes can be verified using the exportfs command:
# exportfs
/mnt/nvme       <world>
At this point, we can connect to the NFS server from other Docker containers.
NFS Client
The NGINX images in the Docker repository support various Linux distributions. It was an eye-opener for us that we are using different Linux distributions, and we decided to unify using Alpine Linux for most of the containers for the current release and move entirely to Alpine Linux in future releases. To use Alpine Linux distributions, use nginx:stable-alpine.
Here is how Dockerfile to build the NGINX image looks:
FROM nginx:stable-alpine
## NFS
RUN apk add nfs-utils
## Entrypoint
CMD ["nginx", "-g", "daemon off;"]
One of the challenges of running an NFS client was to make sure that the NFS server started before clients tried to mount exported drives. For the Theiascope™ platform and Theia web application, NFS is mission-critical, and we decided to wait indefinitely to make sure that NFS is loaded, trying to mount every 5 seconds.
NGINX entrypoint script looks like this:
#!/usr/bin/env sh
echo "${NFS_HOST}:${NFS_MOUNT_POINT} ${NFS_MOUNT_POINT} nfs hard,nolock 0 0" > /etc/fstab
while ( ! mount | grep "on ${NFS_MOUNT_POINT} type" > /dev/null; ) && [ ! "${TEST}" ]; do
   sleep 5
   mount ${NFS_MOUNT_POINT}
done
exec /docker-entrypoint.sh "[email protected]"
If the NFS server fails to start, then NGINX will not start, and the whole application will be unavailable. We tried to use different mounting options in the /etc/fstab file, but we found waiting and mounting manually is the most reliable method.
The API image is based on one of Belana’s base images, balenalib/jetson-nano-ubuntu-python:3.8-bionic, which is based on an Ubuntu distribution and requires nfs-common package to be installed to mount NFS drives. We used the same logic of waiting indefinitely to mount the NFS drive for the API image as the NGINX image. As noted earlier, the API image will be migrated to Alpine Linux in future iterations of the application.
Challenges
It took us a lot of trial and error to figure out the complete solution and work out all the limitations. We would like to mention some of the challenges we encountered with deploying the NFS client/server architecture in a Docker environment.
First of all, when we separated the Theiascope™ platform into multiple containers, we used the most popular images. To support the NFS client/server architecture, we decided to stay with Alpine and Ubuntu only to avoid issues with different distributions. Notably, the most popular NGINX image is based on Debian, which has some problems mounting NFS drives. We did not dig deeper, and simply switched to the Alpine based image.
Another challenge is the lack of NFSv4 support in the included kernel for NVIDIA Jetson devices. The latest release of balenaOS for Jetson devices has modules only for NFSv3 and does not support the required features for the nfs-utils package. We are in touch with balena support to discuss possible solutions. Meanwhile, we use an older version of Alpine for the NFS server.
Another issue was after pushing new updates, devices need to be rebooted in order to successfully load NFS components and connect to the server. We are working with balena support to find the root cause of the issue and a solution that allows pushing updates with only a container restart instead of a device reboot.
For a seamless user experience (UX), the Theiascope™ and associated Theia web application utilizes Grafana. Using the NFS server, all Docker containers use the same volume, and we can effortlessly monitor overall disk usage using the REST API. Users can see the current state of the system resource and free disk space on the home dashboard in Grafana.
All information about the IoT device is displayed on the Home dashboard in Grafana.
One of the additional benefits of choosing the NFS client/server architecture was the ability to connect to external NFS servers for future customers. Simply by overriding environment variables for each container using balenaCloud fleet and device variables, NFS clients can connect to any external NFS server.
Architecture diagram for using external NFS service.
We are still experimenting with this solution and appreciate the opportunity to share our experience with the balena community. We look forward to any feedback.
UPDATE: You can now try this project for yourself via balenaHub.
by Mikhail VolkovMikhail is a Founder/CEO at Volkov Labs and a balena community contributor. He loves to work on innovative projects.
