06 January 2022 / Last updated: 06 Jan 2022
Interfacing balena edge devices with AdafruitIO
Execution time: 30mins - 1hr
If you’re someone like me who can solder wires together, and knows how to program a single board computer to blink addressable LEDs, but always struggles when it comes to creating a beautiful front-end user interface to control them over the web, this blog post is for you.
Learn how to use AdafruitIO to interface with balena devices
Let’s explore how to interface edge devices on balena using AdafruitIO in a low-friction way. We’ll also build a really neat controllable LED project while we’re at it.
The idea
The holidays are that time of the year where every maker creates some LED projects to decorate Christmas trees and add a tad bit of geekiness to it. Keeping the tradition on, this year I decided to build an IoT-ized LED star to place on top of my christmas tree as a jewel and control it from a webUI – change its colors, shuffle effects, maybe also make it react to ambient music and so on.
EDITOR’S NOTE: Custom IoT-controlled LEDs are cool all-year round, so use this guide to learn how to interface with balena devices using AdafruitIO gear with any of your 2022 projects. :)
The build
Initially I decided to 3D print holders to stick my neopixel WS82xx strip and join them together in star shape, connect it to a Raspberry Pi, and write a python script for quick sanity test of connection. However, it was taking a lot of time. So, I decided to go a bit analog and use popsicle sticks as base to stick the LED strip and just solder them together using thin wires and use glue where necessary.
Well everything worked out as planned: the base was strong and the connections were solid, but since this blog is not really about making LED star but rather interfacing balena edge device with adafruitIO, I’ll continue with that part and meanwhile, you can check out the complete build logs on balenaForums here.
So now comes the tricky part: to create a front-end and control the star remotely over the internet. Though I didn't want a really fancy web page, just a color picker with few buttons shall do, but I didn’t want to go down that lane and write it from scratch, more so considering my JS and CSS skills are rusty since forever. There are certain services which allow you to create dashboards which can be used for the same exact purpose and today I’m gonna show you how to work with one of them and it’s really quite easy and straightforward.
Enter adafruitIO
AdafruitIO is the cloud service by adafruit industries created to talk to connected edge devices – microcontrollers and Single board computers. The communication between adafruitIO and the edge device take place over REST API or MQTT. On adafruitIO, users can create beautiful dashboards with widgets such as buttons, gauges, color wheel etc and devices can send and receive data such as sensor value to plot on the dashboard, or a soft button clicked on dashboard can be relayed to the device to take some actions.
The way it works is really intuitive. You create feeds which hold data and these feeds are associated and triggered by widgets on your dashboard. The best part is there are libraries for different programming languages making interfacing with adafruitIO extremely easy and convenient and it also manages all the authentication and connection stuff.
Let’s understand it with a simple example project - controlling a neopixel LED strip attached to a Raspberry Pi with adafruitIO.
  • A Raspberry Pi computer
  • 16GB Micro-SD Card (recommended Sandisk Extreme Pro SD cards)
  • 5v WS82xx based LED strip, also known as Neopixels connected to DMA enabled pin board.D18 on RPi
  • Micro-USB cable
  • Power supply(s)
Step 1 : Connect the neopixel LED strip to Raspberry Pi.
Now there are a few ways to do it, some are safer than others, which may have tendency to destroy your Raspberry Pi board if not done correctly. So for connection, please follow this guide.
Step 2: Login to adafruitIO
You can use an existing adafruit account or create a new one by visiting https://io.adafruit.com.
Step 3: Create a new dashboard
Next step is to create a dashboard which will contain widgets, click on dashboard > create new dashboard and give it a suitable name and description : IoT star, in my case.
Create a new dashboard in adafruitio
Step 4: Add widget to dashboard:
Click on the gear sign and thenadd-widgets, a menu of widgets will appear which you can use, here for this project we will gonna choose a color picker, but feel free to play around and adapt as per your project.
Create a new block in adafruitio
Step 5: Associate widgets with the feeds
This is an important step, as it will tell the dashboard where to send data. Since we’ll be using MQTT, the feed name will become the topic which we will subscribe to for new data/changes from our edge device. Name the feed where color picker will send color value and remember the name as we will be needing it later.
Here you can optionally add new widgets and associate them with same or different feeds, e.g. a push button can also publish 1 or 0 to RGB feed along with color picker publishing RGB values.
Connect a feed in adafruitio
Step 6: Copy the username and active key
Click on My Key button and copy Username and Active Key. This will be used to authenticate to your adafruitIO account.
Connect your adafruit key
Step 7 : Deploy a sample application on Raspberry Pi device
I’ve created a sample project, which you can use to deploy on balena cloud and modify it as per your needs. You can clone the project from here and deploy it on your balenaCloud using balena push or just use deploy with balena button below:
balena deploy button
You can also check out the GitHub repo.
Step 8 : Configure the device variables
Add device variables for your adafruitio setup in balenaCloud
Once the fleet is deployed and main container starts working, we need to add few device variables like - the username, API key and some other parameters to make it work. On balenaCloud Dashboard under devices > device variables add the following variables:
ENV VARIABLEDEFAULT VALUEPOSSIBLE VALUES
NUM_PIXELS60This should be equal to number of LEDs in your strip
BRIGHTNESS0.3Any value b/w 0 and 1, more the brightness more current will be consumed.
ADAFRUIT_IO_KEYN/AKey copied from adafruitIO from step #6
ADAFRUIT_IO_USERNAMEN/AadafruitIO username copied from adafruitIO from step #6
FEED_IDrgbName of the feed created in step #5
Once you submit these changes, the main container will restart and you’re good to go. Go back to the adafruitIO dashboard and use the color picker to change color on the LED strip and it will work all in real time.
How does it work?
AdafruitIO color picker is sending the RGB value of the color we picked over MQTT under the topic /feeds/<feed_name> . On the edge device, we’re subscribing to this topic and whenever a new data comes in, the callback function runs and changes the color of the LED strip. The MQTT broker is also hosted on adafruitIO, so we don’t need a separate broker. Also the connection is authenticated using your API key and username, so it’s secure.
Give it a try
I hope you like this project and get a pretty good idea of how to interface a balena EDGE device with adafruitIO, this is pretty generic across different cloud services on the internet. So give it a try and do share your project with us if you do so on balenaForums, twitter or other channels mentioned down below.
Here's the complete project
As always the project is open-source, feel free to fork, make changes or contribute if you feel so, till then, keep making and let us know what you think in the comments below.
by Ayan PahwaProduct builder and developer advocate at balena
