Also in this month's email:
- Two new IoT project tutorials
- Find out which events we’re attending this month
- New Fleets and Apps on balenaHub
The latest from balena
Communicate with your dog using balena!
New balenista Matt used his dog as inspiration for his labs residency and built a system for her to use buttons to communicate with him; you can find this on balenaHub!
Build your own voice assistant on balena
Otavio has also graduated from his residency this month with his voice assistant using the balena audio block, Rhasspy and home assistant.
The balenaHub Meet-up is back!
Join us on the 27th of September for the 5th balenaHub meetup where we will be discussing Grafana with Mikhail Volkov, the founder at Volkov Labs and using MING with balena ambassador Alex Lennon.
This month on balenaHub
Check out some of our newest Open Fleets, Projects and Blocks on
balenaHub.
- Edt-offline - A low-energy device that creates an access-point serving applications
- balena-passbolt - Passbolt is an open source collaborative password manager
- Plex-seedbox - Quickest and easiest way to get Plex and friends running on a RPi4
- Lumeo-gateway - Create and deploy custom video analytics applications in minutes
- Obico-octoprint - Remotely control your 3D-printer with Obico, Octoprint and balena!
Check out this great video from Volkov Labs where they show you how to use their Network File System to share external storage between containers.
Seeed Studio and Volkov Labs use edge ML on an electron microscope
Using Grafana and balena Seeed and Volkov Labs have collaborated with Theia Scientific to create a real-time AI-powered microscopy image analysis at the edge.
Read all about it here.
Using a RPi and balena to monitor radiation
Events
Meet balenistas and learn about fleet management and balena on these events in September and October:
22-23rd September (Amsterdam, Netherland) - The Things Conference 2022
balena Developer Advocate Marc Pous will be speaking about how you can build your own private LoRaWAN network server and gateway at this year's The Things Conference, find out more and
get your ticket here.
29th September (Virtual) - Edge Impulse Imagine 2022
balena Hardware Hacker Alan Boris will be speaking about running Machine Learning Models on the Nvidia Jetson CPU and GPU, with balena, Cuda and Edge Impulse. Bring your NVIDIA Jetson and join us.
Register here.
7th October (Virtual) - NodeRED Con 2022
balena Developer Advocate Marc Pous will introduce into the nodeRED community the MING stack - An OpenSource LAMP-like stack for the Internet of Things and Embedded Computing.
Register here.
Work with us
We’re looking for a number of roles for our growing team.
Check them out, or if you think you could be a great fit for balena, design your own role and introduce yourself to us via open call. We’d love to get to know you better.
